govenor and throtel ajustment still not right
glen (ontario)
10-25-2003 12:48:28
Ok I am doing something wrong ,Step 1 throtel lever in closed position Stept 2 undo u bolt Stept 3move govener arm back to the rear of tractor and ajust throtel arm so the pin will slide in done all this for some reason when the tractor starts it jumps to full throtel . was wondering if the ajustment on centrifical weights on the cam gear were off ajustment . By the way Jim W is there a Princess Auto in Ottawa they have what I need for that nuckel joint
Jim W
10-26-2003 06:29:28
 Re: govenor and throtel ajustment still not right in reply to glen (ontario), 10-25-2003 12:48:28
Yes, there is a Princess Auto in Ottawa. I will send you an email with directions.
Jim
Jim W
10-27-2003 04:36:05
 Re: Re: govenor and throtel ajustment still not r in reply to Jim W, 10-26-2003 06:29:28
Hi Glen,
I tried sending you an email but it bounced.
Here is how to get there: (Not sure how you would approach it from where you are but) from 417, take Walkley Road west to the first major intersection (Hawthorne or Russell Road, not sure which), then go left (south). Just over one hill and you will see it down on your right.
I hope you have lots of self-control. It's a great place for gearheads.
Jim
glen (ontario)
10-27-2003 15:39:08
 Re: Re: Re: govenor and throtel ajustment still n in reply to Jim W, 10-27-2003 04:36:05
Thanks Jim
john(UK)
10-25-2003 16:51:04
Yeah you are doing it correctly Glen...When you start up does the governor lever out of the timing cover move at all on its own...it should go to shut the engine down..i.e move to the rear...just hold the lever to see if it is trying to control, if it isnt maybe the weights have come off inside. The governor lever should move fully to rear when you close the throttle lever on the dash, when it does that you lengthen or shorten the rod from the carb. so the pin will slide in without moving the rod...then that should be right. Let me know how you go with that Glen, just in case there is something else.
glen (ontario)
10-25-2003 18:01:28
 Re: Re: govenor and throtel ajustment still not r in reply to john(UK), 10-25-2003 16:51:04
When I start up the leaver out of the timing gear cover goes hard foward opening the carb to full throtel ,Your right it should travel to the rear ,I had this engin apart last winter rebuilt it top to bottom I cant even think of how I messed this up .An other point if I ajust the throtel rod so that it is longer the rpms will lower then rise then lower the govener arm rocks back and forth
john(UK)
10-25-2003 18:59:50
 Re: Re: Re: govenor and throtel ajustment still n in reply to glen (ontario), 10-25-2003 18:01:28
If its rocking like you say it is working then, just maybe settings wrong. Does it keep running at full throttle.? Not much you can get wrong really only that rod setting and the other linkage. How long has it been like this,...since u overhauled it or just started doing it?...give me more info and I will check back with you tomorrow....but it looks as tho it is working...I will think more about it.
glen Ontario
10-26-2003 06:03:28
 Re: Re: Re: Re: govenor and throtel ajustment sti in reply to john(UK), 10-25-2003 18:59:50
John it hsa never beeen quite right since I put it back together When I bought the tractor the govener worked fine The engin was in very bad condition so I tore it down and started to rebuild it ,Two years later it sat half put together house renovations ,work , kids and wife got between me and that tractor so I forgot a lot of stuff on the reasembly
john(UK)
10-26-2003 06:14:09
 Re: Re: Re: Re: Re: govenor and throtel ajustment in reply to glen Ontario, 10-26-2003 06:03:28
Hi Glen. Well it seems that it is trying to work if you say the arm does move on its own to the rear,. Really nothing in the timing cover can be wrong unless a weight has broken loose, if you put new weights on that should be ok, but if you didnt that could be the cause, would need you to take cover off to look at it. Start engine and hold the governor arm to the rear,see if it tries to push your hand as it tries to go forward to max revs, just see if it will settle down to a steady speed without revving its socks off, if it will try adjusting that rod to the carb again, lengthening it so it will slow it down some. Sorry to be vague about this but from what you have told me it should work ok. Anyway try that and let me know.
