tractor bucking
tim
10-22-2003 19:52:03
My TO-30 will run like a top for 30 to 60 minutes or so and then it begins bucking/jerking and stalls out. I'll let it sit for a bit and it will run fine again for a couple minutes before bucking and stalling. Any ideas what might be causing this? It has a 6v Genesee ignition. Thanks
TO24424
10-25-2003 18:32:23
 Re: tractor bucking in reply to tim, 10-22-2003 19:52:03
Since your initial post, the info. given leads me to agree 100% with john(UK). Sure sounds like ignition. If it's fuel retriction,...ie "pull the choke" its an awfully small restriction, and I seriously doubt it. How long will it run after the re-start?
john(UK)
10-23-2003 12:05:12
Sounds like ignition component breaking down when it gets hot, the engine stalls so it allows it to cool enough to start again. I am not familiar with the Genesee ignition systen you have so I cant help further but I am sure one of our friends on here will call you with some help shortly.
Jeff-OH
10-23-2003 06:59:43
Are you running the hydrolics when this happens? I have bucking problems when the lift reaches the top if it does not have enough input to pick up the bush hog.
denny
10-24-2003 20:08:42
 Re: Re: tractor bucking in reply to Jeff-OH, 10-23-2003 06:59:43
my to-30 does the same thing after about a hour's
work.what i do is pull the choke out and rev the engine a little and that clears it right up.
then it runs fine for the rest of the day.
tim
10-23-2003 17:41:39
Jeff, it happens with or without the brush hog in operation. The three point hitch is in a level position for the brush hog to cut. Thanks
