MF 165 transmission problem
WEL
10-22-2003 08:54:34
I came across a MF 165 that is stuck in a gear. Without forcing it, the gear shift lever will not move in any direction. Is there any way of trouble shooting the problem without tearing it down? Anyone have any ideas?
Thanks
john(UK)
10-24-2003 11:20:05
 Re: MF 165 transmission problem in reply to WEL, 10-22-2003 08:54:34
You should be able to do it through th oil filler hole at the side of the gear lever, just get all the selectors in line, there will be one out of line just move it with a small bar or heavy screwdriver.
R. Marg
10-22-2003 16:00:08
you should be able to take the top off with out much trouble that should give you a good idea what may be wrong
