JerryM/T and oil filter
Bud
10-22-2003 02:43:43
JerryM/T - I left you a few links under your question about a spin on oil filter for the TO30. Have you had any luck? I am hoping to change my oil this weekend.
deerhound
10-23-2003 17:53:47
 Re: JerryM/T and oil filter in reply to Bud, 10-22-2003 02:43:43
I put on a kit I ordered on the web from SSB Tractor on my MF35. The description for the spin-on filter conversion reads: "This Massey Ferguson engine oil filter adaptor kit fits TO30, TO35 (with Z129, 134 continental engines), MF50, 135. Replaces 1051113M1 plater, 1051114M1 stud, 1051115M1 gasket, 1069954M91 filter with restrictor." I have glanced at my friends TO-30 and I'm not sure if it will work or not. I havent seen his filter housing taken apart, but it appears different from mine on MF35. Let me know if it works? Dale
Jerry/MT
10-23-2003 22:00:57
 Re: Re: JerryM/T and oil filter in reply to deerhound, 10-23-2003 17:53:47
Hey thanks for the put. I'll look into it. It's not the oil filter housing that's important. It's the oil outlet from the block that is. I'll bet the Z129 and the Z134 have the same configuration for the the oil outlet on the block. Thanks again.
Jerry/MT
10-23-2003 10:29:03
Bud, Thanks for the footwork. Can't use the Ford stuff 'cuz they didn't use the Continental Engine. At least I'm not aware that they did.
I did a search in the Ferguson Forum and I found out that there is no conversion kit available per one reply. I don't have a Massey-Ferguson dealer nearby, but that would be the next place to check. I'm busy with some fall work on the ranch so I'll probably get to it ASAP.
