Silly Question on Changing Oil and Filter
LifestyleLadd
10-20-2003 18:22:05
Hi
I know this is a silly question but as a new boy on the block i will ask it anyway.
I have an old TEA 20 with external inclined oil filter. I want to change oil and filter .
Do I just undo the nut on the top of the filter casing and pull off casing (after emptying out oil of course) or is there more to it. I note there are a couple of other nuts on the side do I need to touch them ??
Thanks
PS said it was a silly question but best to be sure
TO24424
10-21-2003 19:12:56
 Re: Silly Question on Changing Oil and Filter in reply to LifestyleLadd, 10-20-2003 18:22:05
Plese...NO SILLY QUESTIONS...I have been an automotive mechanic for 33 years...have never heard a silly question. When I start to restore my TO you'll see some silly questions. Until then have fun & ask questions.
toolman
10-20-2003 19:57:18
no just loosen the bolt on top and then you can unscrew the canister, the nut you call on top is actually a long bolt that goes the length of the canister, down the center inside , once it,s completely unscrewed it will pretty much fall off , dump out the oil take out the filter and check where the top of the canister goes in the grove there will be a rubber seal, you should get a new seal with your new filter,clean the cannister ,put in filter,new seal ,screw it on the bottom of the bolt when hand tight ,tighten the bolt a bit with a wrench,and your finished,the filter number for mine is napa 51302,probably the same for yours.
john(UK)
10-21-2003 11:55:29
 Re: Re: Silly Question on Changing Oil and Filter in reply to toolman, 10-20-2003 19:57:18
On the long bolt through the filter canister there is a plate at the bottom of the filter itself, you may find that is has stuck to the old filter make sure you have this plate in position next to the spring in the bottom of the canister, if you dont have this plate it will not filter the oil at all. It is quite common for this plate to be thrown out with the old filter.
toolman
10-22-2003 01:57:12
 Re: Re: Re: Silly Question on Changing Oil and Fil in reply to john(UK), 10-21-2003 11:55:29
john ,ive never had that problem, but it,s something to watch for , as i could easily see that happening,thanks.
john(UK)
10-22-2003 11:08:54
 Re: Re: Re: Re: Silly Question on Changing Oil and in reply to toolman, 10-22-2003 01:57:12
There was a circlip holding the plate in place originally, if you look you will see the groove it sat in, on the long bolt, but in time and with some rough handling by people who dont really know what they are doing, the circlip comes off with the plate when the filter is pulled out of the canister. It happened quite often over here so I don't think it will be any different with you over there. Anyway just something else to look for.
toolman
10-20-2003 20:01:47
oh one more thing,there is no silly questions,ive found theres alot of good people with alot of good info on here willing to help,so ask away,thats how we all learn.good luck.
