Spark plugs
WayneNJ
10-19-2003 17:39:05
Can someone tell me what type of plug should be used in my 1947 TO-20? Also, what type would you use if you are pushing a little oil? I prefer Autolite brand, but I'm open to suggestions. Does it matter if copper core spark plug wires are used or can the more modern suppression type be used? Thanks, Wayne
Jerry/MT
10-20-2003 18:55:52
 Re: Spark plugs in reply to WayneNJ, 10-19-2003 17:39:05
Wayne,
You need to use copper core spark plug wires. You can find the tune up requirements on this web sitw at the left under "Tune-UP Guide". If you are pushing a bit of oil as evidenced by oily plugs you'll need a hotter than normal plug as an interim fix. Only a new set of rings will cure that problem. Sorry I can't help you with a spark plug number but if you go to the parts people on this site they may be able to help. Hope this helps.
