ferguson valve timing
Jackson Knight
10-17-2003 04:09:17
I need help on timing valves for a 53`to30 with a Z 129 engine. Got the head redone going to put back together this weekend.
Jeff-OH
10-17-2003 04:25:23
 Re: ferguson valve timing in reply to Jackson Knight, 10-17-2003 04:09:17
The #1 cylinder inlet valve opens at TDC. Valves are correctly timed when the single mark on the crankshaft gear is meshed with an identical mark on the camshaft gear.
To check valve timing when the engine is assembled, aadjust the #1 inlet rocker arm adjusting screw to .020. Insert a .005 feeler gage between the #1 inlet valve stem and rocker arm. Crank engine over slowly until a slight resistance occurs when trying to withdraw the feeler gage. At this time, the top center mark should be in register within 1/4 inch on flywheel or 1/8 inch on crankshaft pulley. Reset inlet valve operating clearance to 0.015 cold or .013 hot.--- I&T shop service manual.
