external hydralics use
J. Newton
10-12-2003 17:02:08
I bought a 51 to-20 with a loader. It has hydralic lift and manual dump and reset. I rebuilt cylinders and installed new hoses but can't get it to lift. Am guessing that the 3- point handle should raise and lower the bucket but it doesn't. Lines are hooked to the external hydralic outlets. Is there a valve or switch that makes the external outlets live? 3-point seems strong. Thanks
danct
10-13-2003 09:27:33
 Re: external hydralics use in reply to J. Newton, 10-12-2003 17:02:08
look up Zane Sherman on this site ,he designed an independant pump system for a meyers 7 foot blade in front of a to-30 for me he is easy to talk to and you will have something that works right
Duner Wi
10-12-2003 19:26:22
If the loader is powered by the pump inside the tractor you will need to tie the draw bar lift arms down. If the lift arms raise no more oil is pumped to raise your bucket.
Jerry/MT
10-12-2003 18:15:58
j, Do you have the pump engaged? It's that lever on the left side under your seat. And the clutch has to be engaged. I would think that you need a separate valve for the loader control and a return line back to the pump reservoir.
john(UK)
10-13-2003 11:50:27
 Re: Re: external hydralics use in reply to Jerry/MT, 10-12-2003 18:15:58
There is nothing wrong with your tractor, as a previous writer said you have to stop the 3 point links lifting to the top of their stroke. When the linkage gets to the top of its stroke it shuts the oil supply off till the lnks go down again. What a lot of loader manufacurers did was to supply two extra strong drawbar staybars, that ran from the hinged pin under where the top link is fastened to the 11 hole drawbar on the lower links, that will stop the links lifting and give you a drawbar to pull with. Do NOT fit these to the top link connection on the tractor, just to the hinged pin
