Oil in the wrong place
Jesse Coker
10-12-2003 08:24:18
After a wet winter I was eager to till my garden. I checked the oil in the rear - no water, then the pan - no water, then the radiator - and found about a quart of oil floating on top. I reviewed my collection of advice from you guys but nothing on point. I assumed a cracked block/warped head. Not! The head is off and I still cannot find the water path. I noted only a minor trace of corrosion on the head gasket, from the water to oil port. As soon as I find the nuts I'm going to put her back together. Any advice?
TO24424
10-12-2003 10:30:33
 Re: Oil in the wrong place in reply to Jesse Coker, 10-12-2003 08:24:18
Jesse, The only way, to my knowledge, that oil can get into the coolant is head cracked, or head gasket. Since oil pressure is greater than the cooling system pressure the small area between passages is probably the culprit. Actually, 1/2 qt is not a great amount. Since you have the headoff I would have it magnifluxed, or dye checked, and of course a new head gasket. Also flush the cooling system with a good liquid detergent to keep the oil from attacking the hoses.
