Hi,Today was the first chance I had to try and start the Fergie that has been sitting in the yard since I brought it home. I drained all the oil, took out the plugs and sprayed kerosene in the plug holes. I then turned the engine over with the crank several times. I changed the oil filter which was very dirty and drained the old fuel out of the tank and put in new fuel. I put new plugs in and checked over the wiring before putting in a battery and trying to start her up. I don't have an key for the ignition switch so I tried jumping the two wires at the back of the switch. What is the normal procedure to start a Fergie? Do you just turn the key to active the starter switch as I do not see a separate push button switch on the dash? What is the little red light on the bottom right of the dash? Does it act as an ignition light or as a warning light to let you know that the generator is not charging? Mine comes on when I tap it and then goes out so there may be a loose connection there. I eventually activated the starter switch by bridging across the two terminals. The motor turns over OK but does not fire. I am getting a spark at the plugs so I think that it is fuel related. I noticed when I cleaned the glass bowl that the old fuel was very stickey and smelled like varnish, so I have taken the carb off and am going to try and carefully take it apart and clean it. Is it possible to still get gaskets and parts for the carb? Thanks for the help, Richard
