Troubleshooting Tip -- TO-30 Ignition Switch
Phil(va)
10-10-2003 05:54:58
Had tractor stored at friends place for several months, unused. Went to get it. Turned over good, but wouldn't fire. I pulled gas line to carb and it was getting lots of fuel. Looked for spark at plugs and didn't seem to get any. Then I noticed when I turned on the ignition switch the amp gage did not move to the left as per normal. Pulled switch and it was in bad shape. Jumpered the two switch wires and tractor started quickly. Problem solved. Got to get a new switch today. Just a tip for those with similar problem. Don't forget to check the ignition switch if you aren't getting fire, and it is easy to jumper around it to test. Don't forget these TO-30s will turn over with the switch off, so that's not an indication of the condition of the switch. I'm not talking about the switch on the bellhousing. I'm talking about the one on the dash. Now the other one could be a problem too, but that's another story.
