TE-20 overfill for oil pressure
JR
10-02-2003 18:53:23
I have a TE20 with a Z120 Engine. 0 is ground down with a 9 stamped in it.
Oil level has to be about 1 qt. over full to get any oil pressure. I am thinking something is loose or broken on the oil pump sump.
Any idea?
Jerry/MT
10-03-2003 11:16:08
 Re: TE-20 overfill for oil pressure in reply to JR, 10-02-2003 18:53:23
Could be a cracked pick up tube. Pull the pan off and take a look.
R Austin
10-03-2003 05:20:44
Have you ever changed the oil filter? It is in the oil pan. If you don't get the spring in the correct possition this can some times effect the pressure. Do you have pressure when you first start the engine? Have you checked the pressure guage? These are all possibilities, check back with answers.
David UK
10-03-2003 03:49:59
Sounds like bottom of oil pick up pipe may be missing or have dropped off! BUT, I don't know the innards of this engine so someone else may give a much better response. I offer that as one possibilty only.
