PTO shaft - TO30 finish mower
Larry in Missou
09-30-2003 13:42:36
I have a King Kutter 6' finish mower on my TO30. When I first installed it I had to cut a huge amount of the PTO shaft off to get it to fit with the overrunning clutch. I always left the mower on the ground, never lifted it. Some kid played on my tractor and left the lift handle up, and I didn't notice it. When I engaged the PTO (and therefore the hydraulic pump) the darn thing lifted up and the PTO shaft separated and mashed itself out of shape.
I now have a shiny new PTO shaft. But before I cut the heck out of it, too, I'd like to see if there's a better way. I keep thinking longer lift arms would be good. Or perhaps some sort of extensions on the mower? Or something else? That way I wouldn't have to cut the shaft and it might actually work better if I have to lift it...
How do you all do it?
Thanks!
RWK in WI
10-03-2003 18:45:22
 Re: PTO shaft - TO30 finish mower in reply to Larry in Missouri, 09-30-2003 13:42:36
I have a neighbor who bought a "cheap" quick hitch and uses it between the tractor and his rear mounted mower. It moves the mower back quite a bit and can be removed when you change tractors or mowers. Just an idea.
Scott Medlock
10-03-2003 11:12:28
I resemble that remark!
I lost two PTO shafts that way...
I fixed it with a cable tie locking my lift control in the down position. That fixed that for a whole lot less money than trading in a mower.
Scott
mowr
09-30-2003 15:16:37
Been there, done that! Well, my cut off shaft never got busted up but I was always worried that it would.
I know you won't like to hear this but my solution was to replace the mower with one that has the gearbox at the back instead of the front.
That way I didn't have to cut the standard shaft and the longer arc of travel when raising and lowering let everything work 'according to
script'.
I wouldn't suggest longer arms because when the mower is raised, the extra leverage caused by that would make these tractors even more likely to rear up than they already are.
