Oil leak from Bell Housing
D. Zerbe
09-24-2003 12:34:35
Transmission oil is beginning to drip from the Bell Housing of my TO-35. Not much--I suppose a tablespoon or so after it sits after using it. How important is it to change the seal earlier rather than later. As long as it doesn't drip too much and the transmission oil level stays up any harm in waiting? I have to take the whole transmission apart to get at the seal don't I?
TO24424
09-24-2003 17:11:55
 Re: Oil leak from Bell Housing in reply to D. Zerbe, 09-24-2003 12:34:35
Agree with John. rule of thumb, if the leak (spot on floor) is no larger than the base of a tea cup, wait until it's bigger.
john(UK)
09-24-2003 15:11:09
As long as it is only a drip its ok, but if its anymore than that it may get oil onto the clutch and you will have to replace the clutch plates too. You dont need to strip the transmission, remove the engine and get at it through the clutch housing.
Bill
09-27-2003 04:37:40
 Re: Re: Oil leak from Bell Housing in reply to john(UK), 09-24-2003 15:11:09
I have a similiar leak, but it is transmission fluid. What are your thoughts on that?
Thanks,
Bill
john(UK)
09-30-2003 10:47:13
 Re: Re: Re: Oil leak from Bell Housing in reply to Bill, 09-27-2003 04:37:40
Same reply to you too Bill, providing it is only a drip it should be ok, anything more than that will cause problems with the clutch and possibly the starter pinion gear too.
TO24424
09-27-2003 16:57:57
My persomal thoughts are the same. puddle the size of a tea cup base overnight. Let's face it, if you have to split, youre probably going to replace the clutch anyhow.. Prolong it as long as you can.
