Cracked Block
Krista Wallace
09-20-2003 11:03:04
My radiator keeps leaking out my antifreeze when it gets hot. I have had the water pump replaced three times and it keeps leaking near where the water pump is. I have 1995 Ford Contour. Does anyone know what I can do?
Krista Wallace
09-22-2003 14:23:01
 Re: Cracked Block in reply to Krista Wallace, 09-20-2003 11:03:04
Okay about the head gasket. It looks like it would be hard to get to it. So does your brother know about how much it is going to be to get someone to fix it for me. I know replacing the water pump cost 337.43
thanx
TO-35Man
09-20-2003 17:50:21
Krista...The contours are noted for seeping or blown head gaskets in that area on the edge of the block near the water pump...the only cure for that is to remove head and replace gasket....check for head and block deck straightness when the work is done....most of the time its antifreeze leaking outward from under the head....another quick check is to fill raiditor completely full and crank engine and watch for bubbles in the raditior if it has bubbles you have compression leaking into the cooling system (blown gasket or cracked head)...
My brother works at the local Ford dealer and he says 9 out of 10 times its a blown head gasket...
hope this helps....post back and let us know what you find....
Have a nice day...
David
09-20-2003 12:29:28
Try one of the products that seal leaks. I'm in UK so trade names will be different. There are ones for sealing radiators and ones for sealing block cracks. You normally pour them into radiator and let them run for a while. That's if you're sure its a crack or leak and not a leaking gasket or seal.
