brake drum TO30 removal
Paul (FLA)
09-18-2003 04:56:27
I got 1 flat head screw out, and broke my impact tool on the other. I hav been dowsing with liquid wrench, and trying to move the sucker.
Anyone have any methods to removing the other big flat head screw?
Paul (FLA)
09-22-2003 04:50:50
 Re: brake drum TO30 removal in reply to Paul (FLA), 09-18-2003 04:56:27
Finally got the bugger out.
I kept tapping on it with a hammer, Try to turn it with a screw driver, and walk away. Over the course of a few days doing this, I then took a flat head and a hammer, and tried to turn it by chisel method. Sunday morning, in my PJs it turned. After breakfast, I replace the bearing seal with a sure seal. Success!
MIKE (FL)
09-19-2003 05:32:32
IF YOU DO HAVE TO RESORT TO DRILLING DONT DESPAIR. START WITH A GOOD CENTER PUNCH, MOVE TO A 3/16 BIT, THEN TO THE SIZE OF THE BOLT. USE A FAIRLY SLOW SPEED DRILL AND A GOOD LUBRICANT. JUST MAKE SURE THE CENTER PUNCH IS CENTERD AND THE DRILL IS STRAIGHT. EASY JOB, JUST TAKES PATIENCE. GOOD LUCK!
Ford Man
09-18-2003 19:50:20
The slots on mine were too boogered up to use a screwdriver . I wound up welding a 1/2" bolt to each of them and using a wrench on the bolt head to unscrew them whil they were still hot .
Worked like a charm .
Good Luck !
Ford Man
marlowe
09-18-2003 17:06:45
heat the head and then give it a rap then if you get it out leave it out
john(UK)
09-18-2003 12:00:11
You may have to drill it out...sorry.
