TIMMING ACCESS HOLE TO-20
STEVE MO
09-16-2003 13:41:17
COULD SOMEONE PLEASE TELL ME WHICH SIDE OF THE TRACTOR THE TIMMING ACCESS HOLE IS ON, LOOKED ALL OVER THE FLYWHEEL COVER AND FOUND NO HOLE. THANKS
RP
09-16-2003 14:03:42
 Re: TIMMING ACCESS HOLE TO-20 in reply to STEVE MO, 09-16-2003 13:41:17
Left side when sitting in the seat. I just set my timing a few weeks ago. It a sheet metal plug about 1" in diameter with spring fingers you need to pry out (and push back in when you're done). It may not be obvious under the paint, dirt, etc.
Take the distributor cap off and crank it (with ignition off!) until the rotor points at the #1 plug position (the wire leading to the front of the engine). The marks on the flywheel should be visible in the hole. If not, crank it around again one more turn. It helps to reach in with a rag on a screwdriver and clean the marks off and then scratch with chalk.
Hope this helps
john(UK)
09-16-2003 17:21:57
 Re: Re: TIMMING ACCESS HOLE TO-20 in reply to RP, 09-16-2003 14:03:42
If yours doesnt have a plug to remove. you can remove starter and view timing marks that way.
