Quadrant control 135
Mike A
09-15-2003 16:54:16
Just purchased a 135 deluxe. It's a great tractor. Right now I have a Ford 8N and a Ford 3000.
The question is:
I have no owners manual for it. The quadrant control has 2 levers. The position control and draft control. Can someone explain to me how the draft and position control quadrants work?
I was told the tractor year is about 1971. The serial number is 9A30794.
Thanks in advance.
Basil Greenleaf
09-17-2003 05:48:37
 Re: Quadrant control 135 in reply to Mike A, 09-15-2003 16:54:16
The inside lever (nearest to the seat) is position control. Use this lever to hitch to an implement or unhitch or any time you want to maintain a set position, such as a post hole digger. The position control lever has to be in the raised position to use draft copntrol. (the outside lever) Use draft control for plowing or any three point linkage equipment used in the field. I also use it for grading my driveway. It's a great system. Have fun. (An old MF engineer)
chrismf135
09-15-2003 17:30:29
leave your email i'll send that section of owners manual
Guy
09-17-2003 09:06:50
 Re: Re: Quadrant control 135 in reply to chrismf135, 09-15-2003 17:30:29
Hi, I'd love a copy if its not too much trouble.
Remove the '.remove' from this address:
[email protected]
Thanks
john(UK)
09-15-2003 16:57:14
I have a sheet that explains how to use the hydraulic sytem on this tractor if you would like a copy let me have an email address I can send it to.
guy
09-17-2003 09:10:19
 Re: Re: Quadrant control 135 in reply to john(UK), 09-15-2003 16:57:14
Hi John, I'd love a copy if its not too much trouble.
[email protected]
Thanks
Mike A
09-15-2003 17:17:05
John, thank you for the prompt reply. I checked off the Email notification box. John, can you verify if the year of the tractor is correct?
Thanks, again.
john(UK)
09-15-2003 17:23:34
 Re: Re: Re: Quadrant control 135 in reply to Mike A, 09-15-2003 17:17:05
Regarding the serial number and year I dont have the american serial numbers for the 135 but someone will reply to you shortly. That box you ticked off is only to tell you when you get a reply to this query, I cant send the sheet to you on here it has to be done to an email address.
Mike A
09-15-2003 18:20:24
 Re: Re: Re: Re: Quadrant control 135 in reply to john(UK), 09-15-2003 17:23:34
My email address is
[email protected]
Thanks
