Which Ferguson is best for me?
Joe
09-12-2003 14:31:07
Hello, Iam going deaf running my old two cylinder John Deeres, and want to try a quiet tractor like the ferguson. I only bushog 10 acres, pull a manure spreader, and pull-out old fence post, and auger new fence post holes. Which ferguson is the quietest and best for me. Thanks, Joe
RAR/IA
09-13-2003 15:49:08
 Re: Which Ferguson is best for me? in reply to Joe, 09-12-2003 14:31:07
A good pair of ear plugs or protectors are by far less expensive. You are already comfortable with using your Deeres. If you are losing hearing, other things like chainsaws do as much or more damage than most tractors unless running straight pipes. Food for thought.
Roger
Phil(va)
09-13-2003 07:42:20
Get one of each. That's what most of us do. It's only money.
Ray,IN
09-12-2003 18:48:15
Your last use is the important one. I would suggest a Ferguson 35. The 20/30 series tractors do not have live PTO, and using a post hole auger without live PTO be quite an experience if you hit a large tree root or rock. (BTW, the auger is rated the most dangerous of all farm machinery) A PTO driven manure spreader will likely require more HP than the 20/30 series tractors delivery.
john(UK)
09-13-2003 05:39:50
 Re: Re: Which Ferguson is best for me? in reply to Ray,IN, 09-12-2003 18:48:15
I agree with Ray and plus the 35 has position control for the hydraulics, makes life much easier boring post holes. Just in case you need telling, you want a tractor with a live PTO, maybe called livedrive too or De-luxe depending on the model you look at.
