TO 20 valve spring retainers
Terry
09-11-2003 16:16:30
I took the head off my TO 20 the intake valves are pin type the exhaust have regular keepers. In the valve kit I ordered the exhaust valves are pin type. Can anyone tell me where to find four pin type valve retainers.I have been told that this is not an after market product by several companys.
Terry
09-13-2003 04:40:58
 Re: TO 20 valve spring retainers in reply to Terry, 09-11-2003 16:16:30
Has anyone ever had 2 different types of valves in a head?
Duner Wi
09-13-2003 05:58:31
 Re: Re: TO 20 valve spring retainers in reply to Terry, 09-13-2003 04:40:58
Sealed Power lists Ex. valves both ways. Drilled stem or 1 groove valve stem for the TO 20. I will guess guess the Rotocaps used the 1 groove valves. If you don't have Rotocaps you got the drilled stem.
Terry
09-14-2003 06:18:15
 Re: Re: Re: TO 20 valve spring retainers in reply to Duner Wi, 09-13-2003 05:58:31
I have the rotocaps I don't have new grooved valves, I'll check sealed power. In the kit I recieved the valve springs are the same height. The exhaust valve springs that came off my head are shorter than the intake springs. Do you know anything about this? Thanks a bunch for your help so far.
