To30 gearbox question
Hartmut Boegel
09-10-2003 04:36:23
would like to use my to30 with a snow blower.
The reverse speed is a little to fast and not having a live pto does not help.
Here is my question:somebody told me that there is a so called Schermann gearbox available.
Does anybody know where i could find one?
How much it would be and how hard it is to put in?
Also , what type and grade engine oil and gasoline are you guys using?
'Ole Henry' (Va)
09-11-2003 04:46:41
 Re: To30 gearbox question in reply to Hartmut Boegel, 09-10-2003 04:36:23
Just browsing from the Ford 9N/2N/8N forum and noticed your post about the Sherman transmission. Lots of discussion over there about using Sherman's for rototillers.
Sherman's were made in the step-up, step-down, and combination versions, the most popular being the combo unit. All units were installed in front of the transmission and gave additional ranges to the regular transmission (combo gives the equivalent of 12 forward and 3 reverse speeds for a four-speed transmission). This was before there were many PTO operated implements and pulling speeds were the main factor.
For your purpose, you want to slow the tractor down (combo in low-range, or a step-down version), problem is this would slow the ground speed but, it will also slow the PTO speed, assuming the Ferguson's and Fords have the same rear-end design, and I think they do. Increasing the throttle to increase the PTO speed will increase the ground speed, so you are back to where you started from.
I have a combo in my '51 8N and like it, but it doesn't solve all problems. Below is a good link about Shermans.
Link
Hope this helps.....John A
Jerry/MT
09-10-2003 11:00:25
Hartmut,
I have a 1954 TO-30 and I use 10W40 engine oil with the lastest specification (SJ?)and regular unleaded, 87 Octane ((R+M)/2)gasoline. These are the same things I use in my gasoline fueled cars and trucks. I add a pint of STP Oil Treatment to the oil and some Stabil gas preservative to the fuel. The Sherman Transmission that is basically a hi/lo transmission was available for these tractors. It was installed in the bell housing ahead of the regular transmission. I'm not sure but I don't believe they are still available new, but you might call some tractor salvage yards and find a used one. They were installed in some new tractors by the selling dealerships. Do a search in the archives on this site and you'll find some info regarding the Sherman Transmissions. Hope this helps.
