TEA 20 OIl Leak
John Ludington
09-08-2003 19:36:28
I have a 1951 Tea 20 with a Standard engine. It leaks oil from the head to block joint on the left rear side of the engine. Would a new head gasket seal this? If so where could I purchase one. I live in Souther Ontario Canada. Thanks for any help.
john(UK)
09-09-2003 12:02:10
 Re: TEA 20 OIl Leak in reply to John Ludington, 09-08-2003 19:36:28
Yes it sounds as though its leaking from the point at which the rockershaft is supplied with oil and in that case it would cure it. I would suggest that if possible you get a complete head gasket set for it because you will need more than the head gasket. Sparex part number is S42085 for gasket set and S42253 for head gasket only, I am assuming that your engine is 85mm bore and NOT 80mm, if it is 80mm the part numbers will be wrong. Try both these sites or maybe you know a Sparex dealer near to you.
Link
ALSO>Link
Check that the head is flat and not warped or it may occur again, no gasket cement is necessary or desirable on the gasket, just use a film of grease.
