TE20 Steering wheel replacement
R Austin
09-05-2003 18:33:44
What is the diameter of the Steering Shaft,on my 1949 TE20,where woodfuffkey is located? Have a steering wheel,with key slot, that has 3/4 inch diameter hole. Will it work if I remove old wheel. Present wheel is in real bad shape.
john(UK)
09-06-2003 06:51:05
 Re: TE20 Steering wheel replacement in reply to R Austin, 09-05-2003 18:33:44
TE wheel centre has a taper too, not a straight hole just to make things awkward. You should be able to get one easily though, the Sparex part number is S41486 which is the later type or the original type which is slightly dearer is S61373, this has steel spokes in the wheel. Just in case the Dome nut that holds the wheel on is part number S40290. You should have a Sparex dealer somewhere near to you.
