installed 1 3/8 PTO shaft and now stuff won't fit
George
09-02-2003 19:48:12
I had used and adapter on my 1 1/8 shaft to operate a brush hog. Since the seals were leaking and the spline was damaged, I decided to put a 1 3/8 shaft in.
Now I cannot hook up my newer Kioti finish mower. It seems to go on the first part of the shaft but will not fully engage. This implment does mount easily on my Kioti tractor, which also accepts other 1 3/8 stuff.
Any idea for this problem....should I try and clean up any burrs (I don't see or feel any however)
Thanks
Jerry/MT
09-02-2003 21:43:31
 Re: installed 1 3/8 PTO shaft and now stuff won't in reply to George, 09-02-2003 19:48:12
George:
Most PTO's that I am familiar with have a little button on the end of the implement PTO shaft fitting that you have to push in to attach the shaft to the drive. The spring loaded pin engages a notch on the PTO shaft when you release the button. Does your shaft have such a button?
