TO20 overrunning clutch
Mike H
09-02-2003 05:03:07
I have a TO20 with an overrunning clutch. It works fine but has developed some end runout which Im not sure was/is normal. I took the clutch off the pto(1 1/8 shaft) and noticed that the roll pin that goes through the tractor pto shaft had enlarged that hole. Is this normal wear or should I be looking for a new pto shaft? I believe a new roll pin might snug things up somewhat. Any comments? Where can I get a new shaft should I need one? THANKS
