To 30 z129 cylinder sleeves
marc
08-31-2003 01:11:40
I have a slight coolant drip at the bottom of number four cylinder.Are these cylinders dry or wet with seals? Could i have a cracked block? Any info would be greatly appreciated.
Jerry/MT
08-31-2003 14:09:01
 Re: To 30 z129 cylinder sleeves in reply to marc, 08-31-2003 01:11:40
Marc:
It's very common for the Continental Z129 Engine to have cracks in the block. They usually occur between the cylinders (which have wet sleeves). My original engine had them and they were repaired by drilling holes completely through both sides of the block between the cylinders and placing a threaded rod with double nuts on both ends of the threaded rods and tightening them down. I replaced the engine, (which needed a complete rebuild), with a short block that was oven brazed to repair the cracks. Runs like a top now.
Hope this helps.
