TE-20 Need piston for STANDARD engine
Mike
08-29-2003 11:55:30
I need to find where to get parts for my ferguson tractor. I need a piston, set of rings and a manafold. Problem is that is is not the Z120 engine but a "standard" engine with 87mm 4 ring pistons. Thanks
john(UK)
08-29-2003 14:04:54
 Re: TE-20 Need piston for STANDARD engine in reply to Mike, 08-29-2003 11:55:30
Depends on where in the world you are, plenty of parts though, lets us know your location. 87mm in a TE20 is not usual, TE20 was only fitted with 80mm & 85mm pistons, it is possible this engine has been worked on before, but check the bore size again before you order any spares. 87mm engines were used in FE35/MF35 models
Mike
09-18-2003 09:00:15
 Re: Re: TE-20 Need piston for STANDARD engine in reply to john(UK), 08-29-2003 14:04:54
Thanks for the information, I located one in Wisconsin
john(UK)
09-02-2003 12:32:32
If you havent got a piston yet...try this site.
http://www.dwsmotormachine.biz/MF_standard_engine.htm
