Sagging Wagner
JS
08-26-2003 12:40:29
My Wagner front end loader is sagging (Its mounted on a '53 Ferguson TO30). After about 30 minutes of steady use the arms and bucket are very slow to operate. If I continue the arms will only raise part way then start to sink to the ground. Also the bucket cylinder will not curl back the load. If I release the valve the arms will still continue to lower slowly. I do not have leaking or bypassing cylinders. I have tried resetting the relief valve and no change. With that in mind I have condemned the control valve or am I barking up the wrong troubleshooting tree.
Does anyone know where if the valve is rebuidable and where does someone get the parts? If its not where does someone get the replacement valve.
Thanks Guys!
