stabilizer arms,what length for to 30?
jeff
08-23-2003 19:44:09
i bought stabilizer arms today for my to30,they are 31.5 inches long(too long)i measured tonight looks like they should be 28.5 inches long,the brackets were already on the tractor from when i bought the tractor,(the brackets that the stabilizer arms go to) could the brackets possibly be on the wrong sides,it looks like if i swap them the pins that the arms go onto would be a little further distance,allowing the stabilizer arms to fit.does anyone know what length arms i need?
jeff
08-24-2003 12:46:19
 Re: stabilizer arms,what length for to 30? in reply to jeff, 08-23-2003 19:44:09
thanks dave,the brackets were on the wrong sides,i had to swap them,it put the pins further away now the stabilizer bars fit good.thanks for your help.
David
08-23-2003 21:43:40
The pins that the stablisers fix to should be in line with the lower link arm pivot point (both horizontally and vertically). If it isn't something needs changed to get it there. If that is ok you might have an incorrect stabliser. Don't know length offhand and can't measure as someone has mine on loan with a machine.
