TO35 loader issue (need a stinger)
Joe in Houston
08-20-2003 11:22:16
I am bidding on a front end loader that came off an 8N. I know I may have to modify the mounts a little to make it fit but it should work fine. The problem is that it is missing the stinger (Rod that goes from the front mounted pump, through the tractor and connects to the crankshaft). Anyway SInce I do not know where I can get a Stinger is there anyway to make one from pipe or something.?
Any syggestions would be appreciated.
Scott
08-21-2003 10:21:28
 Re: TO35 loader issue (need a stinger) in reply to Joe in Houston, 08-20-2003 11:22:16
Hi Joe There is no need to make one the name and number I am going to give you is a antique tractor salvage yard. They have parts for everything and have what your looking for in all lengths and sizes to fit most tractors these are all new parts. They are Lakeside Farm Implements 1-800-365-4863 N 6891 Co. Rd. B Montello,Wi 53949
larry
08-21-2003 04:32:19
Joe,i have a stinger, will send a picture,this would be easy to make. the hard part will be the part that bolts to crank shaft.
Joe in Houston
09-12-2003 09:27:27
 Re: Re: TO35 loader issue (need a stinger) in reply to larry, 08-21-2003 04:32:19
Larry,
Never got the pictures. would apprecite them.
Thanks Joe
toolman
08-20-2003 23:09:21
i have a 2085 with a loader i go to the local machine shop , he makes mine up for me 3/4 shaft about 11in. long cuts key ways for wood ruff keys , seems to work ok.
Phil(va)
08-20-2003 16:22:27
Try your local New Holland dealer. They sometimes had them. You should be prepared for some mods to hook up the loader on the 35, as it is longer, axle to axle, than an 8N, about 2.5 inches if memory serves.
Paul (FLA)
08-20-2003 12:21:34
I have a loader on my TO30.
I think it was made by walker. I can try to find out more about the manufacturer, for they might have a stinger that will fit the 8n.
Let me know if you want to know about the stinger config that I have.
and yes, I would think you could make one.
