TO-20 Spindles
Clint
08-15-2003 12:09:06
Ok just got done removing and replacing front spindle bushings on my TO-20 and now I cant get the spindles back into the housing, all I have is a brake hone to ream with any other suggestions??
Fred OH
08-19-2003 09:44:38
 Re: TO-20 Spindles in reply to Clint, 08-15-2003 12:09:06
Take a half inch wooden dowel that'll fit in your 1/2" electric drill and probably a half foot long...saw a slot in one end (across the diameter)...put some stiff emery paper in the slot...probably 120 grit...crowd it into the lower bushing area first and use it like a hone...and check fit of spindle very often...I think you only need to take out a thousandth or so...don't take any off of the spindle...it has to fit the arm up on top. If you can't find stiff enough emery or sand paper...try backing it up with a piece of tin. The new bushings will not take much play out if you have wear in the spindles. They can be welded up and belt sanded down...depending on how handy you are with metal...OR if you have access to a 16 to 20" lathe and a fixture to hold the spindle end centered...you can undercut the wear areas, weld them up and turn them back to factory specs. L8R....Fred OH
Duner Wi
08-15-2003 17:41:30
My TO 20 spindle bearing surfaces were worn some. I had mine reamed just so you could slide the spindle thru the bushing. When it got to the wore part on the spindle I had plenty of clearance.
TO-35Man
08-15-2003 14:05:11
Clint , you will be there a week trying to use a brake hone to size those bushings...I'd try to borrow a ream or you might have to pay someone to ream them for you....unless you want to buy a ream but they are not cheap. All things considered I'd rent a ream or borrow one...try a local shop that does front end work...you never know till you ask....
have a good day...
