Oil grade for FE-35
Tasmania
01-11-2000 13:22:10
I have rebuilt a Ferguson 35 which has a 4 cylinder petrol engine from Standard Motor Co. The rebuild included the pistons, sleeves, rings and the big and main bearings. What is the correct grade of engine oil to use here? Thanks for any help.
Jim Duncan
01-27-2000 22:59:26
 Re: Oil grade for FE-35 in reply to Tasmania, 01-11-2000 13:22:10
The oil requirements are for five quarts (plus one for the filter) of S.A.E. 30 above 50 degrees F. or S.A.E. 20 below 50 degree F. or S.A.E. 10W below 10 degrees F. Also the manual recommends that "detergent type lubricants" be used. I presume you used some type of "rebuild" lubricant on the bearing surfaces and friction areas in the reassembly process! I hope this helps. . . Jim
