fuel shut off valve
Mike
08-09-2003 23:26:22
Just put a new fuel bowl assembly on my 35. The shutoff valve leaks a tiny bit. Any help on this, don't want to tighten too much.
Mike
08-10-2003 21:02:47
 Re: fuel shut off valve in reply to Mike, 08-09-2003 23:26:22
TO35Man, I didn't use tape on o ring threads, don't know how much to tighten. Thanks
TO35Man
08-11-2003 03:00:58
 Re: Re: fuel shut off valve in reply to Mike, 08-10-2003 21:02:47
Mike ...tighten just enough with a wrench so you can't move it by hand when your through.
Mike
08-11-2003 07:03:55
 Re: Re: Re: fuel shut off valve in reply to TO35Man, 08-11-2003 03:00:58
Thank you Sir
To35Man
08-10-2003 06:13:52
Mike....when you installed the shut off did you use sealer or thread tape on the threads?
and if its leaking out of the stem you can snug up the packing or o-ring nut ...if that does not work remove it and take apart clean and replace o-ring and or packing....
hope this helps
