to-30 part
charles
08-08-2003 18:54:56
i am looking for a 12volt starter for a 1951 to-30 frugusion anyone know where to get one
Jerry/MT
08-09-2003 13:48:55
 Re: to-30 part in reply to charles, 08-08-2003 18:54:56
Charles;
You don't need to change the starter when you convert to 12 volts. The starter will actually use one half the current at the higher voltage which means less heating of the field coils and longer life.
Hope this helps
Phil(va)
08-08-2003 20:28:57
The normal six volt starter will work just fine with 12 volts. You can have it rebuilt at an automotive electrical shop if you really want to, but unless you grind it heavily it will give good service indefinitely without doing that unless it has some other problem. A 12 volt conversion normally does not require you to change the starter. Now it occurs to me that you might not have a six volt starter either, and that is more perplexing. In that case, try the salvage yards, such as Mac Tractor in Colcord, OK, for example.
