Bouncing Hydraulics
John W
08-07-2003 17:28:56
Ive got a '52 TO-30, runs really well but the hydraulics seem a bit iffy. The three point seems to lift ok but when its all the way up with an attachment on it bounces like crazy. Also when the tractor is turned off the three point drops like a rock. Ive looked in the side covers but can see no oil spray or large amounts of turbulence. Could this be an adjustment problem in the control spring or quadrant,rather than a mechanical issue such as a relief valve??
jeff
08-09-2003 06:28:59
 Re: Bouncing Hydraulics in reply to John W, 08-07-2003 17:28:56
John,did you figure it out? my 51 to30 does the same thing,shakes,bounces,going down,and lately if there is an attachment on the back,tractor not running,it goes down but not fast,it goes down slowly.
John W
08-10-2003 08:41:01
 Re: Re: Bouncing Hydraulics in reply to jeff, 08-09-2003 06:28:59
Not 100% yet but for starters I checked the control spring and quadrant settings and got them where they should be. The bouncing really settled down with an attachment in the full up position. If you dont have a shop manual the site refered to by TO-35MAN has the same info. Next Ill have to dig into the relief valve which seems to be the most likely culprit for the rapid droppage issue. Good luck Jeff!
john(UK)
08-11-2003 11:34:40
 Re: Re: Re: Bouncing Hydraulics in reply to John W, 08-10-2003 08:41:01
Unlikely that it will be relief valve causing that problem...it would cause it not to lift much weight if there is any fault with relief valve
toolman
08-07-2003 19:16:31
is it low on oil?
Phil(va)
08-07-2003 18:16:46
IMHO, and in a word, NO.
TO-35Man
08-07-2003 18:44:21
 Re: Re: Bouncing Hydraulics in reply to Phil(va), 08-07-2003 18:16:46
Hi Phil....take a look at this site...it will tell you everything you need to know.and its easier read on thier site rather than me making a long post here....
hope it helps if not post back here
http://www.holland-brand.co.uk/infofiles/hydraulic.asp
Phil(va)
08-08-2003 20:12:35
 Re: Re: Re: Bouncing Hydraulics in reply to TO-35Man, 08-07-2003 18:44:21
I'm not the guy that asked the question. Perhaps you meant to direct your reply to him...?
TO-35Man
08-09-2003 04:06:42
 Re: Re: Re: Re: Bouncing Hydraulics in reply to Phil(va), 08-08-2003 20:12:35
Sorry about that Phil...My mistake
john(UK)
08-08-2003 11:42:36
Sounds like control spring needs end play removing. When you get end play in this it alters all the settings on the internal linkage. There should be no end float at all, but you should be able to turn the spring when you have an implement in the raisd position, for most settings they specified using a 2 furrow plough (2 bottom plow in USA) as this was right weight and provided the correct leverage.
