TO-20 Back Hoe Cylinder Leaks
Don in MI
08-06-2003 17:26:24
I'm looking to buy a TO-20 with (I believe) a Wagner front loader and back hoe. The back hoe is a ridgid mount, not 3 pt. Here's the problem...two hydraulic cylinders leak big time. One for the loader lift and the other is for a rear stabilized arm.
I see that the chrome is pitted on the cylinder pistons. Are these expensive to replace? Where can I get the parts?
Also, the price is $2900. Is this a good deal?
Don
Batman
08-07-2003 01:03:58
 Re: TO-20 Back Hoe Cylinder Leaks in reply to Don in MI, 08-06-2003 17:26:24
Like Marlowe said - cost for a rebuild on a ram is usually around 80 pounds sterling - less if all that is needed is new seals.
Stripping the rams is easy if you have a big Stilson wrench, and a large vice to grip the cylinder - just keep everything really clean - dirt is what kills rams fast.
marlowe
08-06-2003 20:13:23
any good hyd. repair shop can fix you up
