Old Ferguson Identification
Gary
08-05-2003 07:43:30
I started this search in the Ford forum (any tractor knowledge I have is in the John Deere department) but they were quick to point out that the tractor I'm looking at is a Ferguson. The s/n on the panel in front of the steering wheel is a clear TEA306233 and the engine s/n is also clear SC39258. I've posted some pictures at the website below. I'd appreciate anything you could tell me about this tractor. It is used daily thru the summer to tend a fishing weir so it's driven in salt water and parked on the beach 24/7 so it isn't in pristine condition.
Link
Batman
08-05-2003 07:49:58
 Re: Old Ferguson Identification in reply to Gary, 08-05-2003 07:43:30
If you had looked down the column to your left, you would have found a section called Research & Info and within that, Serial Numbers.
That would have told you all you needed to know, just by looking up your serial number.
If you were to look at the engine, it should also have a plate rivetted to the LH side, which will have yet more numbers than the ones you have listed possibly beginning with Z12XXXX, and they will confirm what you learn using Research & Info.
HTH
Batman - No, no plate
08-05-2003 08:04:54
 Re: Re: Old Ferguson Identification in reply to Batman, 08-05-2003 07:49:58
As it is a Standard engine from the UK, so no Z12XXXX either.
Why did you start on the Ford board as the serial number plate has Ferguson on it?
(ex JD6400 AWD and Ford 8210 AWD driver - but I got over it)
Gary
08-05-2003 08:48:46
 Re: Re: Re: Old Ferguson Identification in reply to Batman - No, no plate, 08-05-2003 08:04:54
As I mentioned, my expertise is not in Fords or Fergusons. The plate you mentioned probably did say Ferguson at one time but the ravages of time and saltwater have left the stamped serial number the only legible item.
The serial number section you mentioned doesn't say anything about s/n's with an "A" in them.
Batman
08-06-2003 00:02:52
 Re: Re: Re: Re: Old Ferguson Identification in reply to Gary, 08-05-2003 08:48:46
The model of the tractor is a TEA, (Tractor, England, A). The serial number gives you the approx date of manufacture.
john(UK)
08-05-2003 10:35:00
From the information you have given, the tractor is a 1952 model, should be 12v
Gary
08-06-2003 03:19:53
 Re: Re: Re: Re: Re: Old Ferguson Identification in reply to john(UK), 08-05-2003 10:35:00
Thanks to all for your help. In my search I found the page below which explains all of the letters of the Ferguson s/n. I hope it's useful to those who haven't found it yet.
http://www.users.bigpond.com/jrduff/serial.html
