AIR CLEANER/CARB CONNECTOR
JIMOK
08-04-2003 20:18:20
I have just purchaced what I have identified as a 1954 TO 30 based on the model # The tractor is missing the connection between air cleaner and the carb any suggestions for finding this part? Thanks for any help.
Scott
08-04-2003 21:07:34
 Re: AIR CLEANER/CARB CONNECTOR in reply to JIMOK, 08-04-2003 20:18:20
Try a piece of radiator hoze 1 5/8 in diameter I think in diameter about 2in long.
JIM, OK
08-04-2003 21:28:26
 Re: Re: AIR CLEANER/CARB CONNECTOR in reply to Scott, 08-04-2003 21:07:34
THANKS FOR THE HOSE IDEA. THE AIR CLEANER IS LOCATED BEHIND THE DASH WITH INTAKE IN THE DASH WHILE THE CARB IS AN UPDRAFT MID ENGINE ABOUT 12" AWAY. IT SEEMS IT HAS TO WIND AROUND THE CHOKE CONTROLS SO WAS WONDERING IF THERE WAS SOMETHING SPECIAL
James, UK
08-05-2003 00:39:51
 Re: Re: Re: AIR CLEANER/CARB CONNECTOR in reply to JIM, OK, 08-04-2003 21:28:26
There is an after market product made for the TE series, which is a 12" approx length of steel pipe to join the parts you mention. You will also need two extra hoses, one of which is 'waisted' to reduce from pipe OD to carb OD
email battelle at btinternet dot com at The Old 20 Parts Co. for more information, they can supply and ship. Mine were also missing.
