bush hog master control spring
Brent, IN
08-04-2003 19:00:31
I thought of getting safety chains for my Howse 5' bush hog. A place wanted $225 for a set! Someone else suggested bolting on a wide rubber belt instead. Any thoughts out there? Also how do you loosen a stuck master control spring? Thanks!
James, UK
08-05-2003 00:34:09
 Re: bush hog master control spring in reply to Brent, IN, 08-04-2003 19:00:31
By safety chains, do you mean (a) chains to stop side to side sway, or (b) to 'hold' the hog at the right height?
If (a) you can use a suitable length of chain around each axle housing, then round the lower link arm, and joined by a suitable shackle - much less than $225 :)
If (b) you can make up a bit of linkage - and add two lengths of chain to run from the top link (ideally not the yoke, the long pin) to the lift arms at the hog connection - also less than $225. I can email you a nice solution from the Ford N board if you are interested, 'fraid i can't remember who did it, but it was very neat.
Unsiezing the threaded rod on the control spring needs to be done very carefully, and over several weeks using a combination of heat and something similar to WD40 or PB blaster or similar.
To check if the linkage on the spring is working as it should, and for info on adjustments, go to the link below.
A quick and dirty check is to stand on a 9 hole drawbar, and insert a pry bar into the yoke, and lever against the spring - the drawbar should lift after almost imperceptible movement/compression of the spring.
HTH
Brent, IN
08-05-2003 09:23:08
 Re: Re: bush hog master control spring in reply to James, UK, 08-05-2003 00:34:09
James,
Thanks for the info on the control spring. I take it that patience is the key. What I mean by safety chains are the chains that hang on the front and rear of the mower to protect the driver from flying objects coming from the mower.
Batman
08-06-2003 00:06:07
 Re: Re: Re: bush hog master control spring in reply to Brent, IN, 08-05-2003 09:23:08
Aha, OK, now I see what you mean - in that case find a local supplier of industrial rubber sheeting (you may get some strange numbers from directory enquiries, lol), and buy some direct, and then cut to fit.
3/8 of an inch should be thick enough - cut with extreme care with a knife, or better yet use a jigsaw, then drill for bolts to fix to the frame.
Brent, IN
08-06-2003 13:21:43
 Re: Re: Re: Re: bush hog master control spring in reply to Batman, 08-06-2003 00:06:07
Thanks, James. I found some at a place called Tractor Supply Company. They have belt material in bulk used for balers. Also, when I try to loosen the master control spring should I have an implement attached? Am I to grab the spring while trying to turn the threaded yoke? Thanks.
Batman
08-07-2003 00:54:18
 Re: Re: Re: Re: Re: bush hog master control sprin in reply to Brent, IN, 08-06-2003 13:21:43
Brent, be very careful here - if you have removed the hinged yoke (top link connection) so that you can try to turn the end of the rod that comes out of the spring DO NOT under any circumstances have anything mounted on the 3pt - it will bend the rod that goes thro the spring, and knacker the system completely.
Did you check for easy/difficult spring rotation as per the link to Holland Brand in the above posting?
Did you try the prybar test on the top link?
Normally, the spring will get 'looser' over time, not tighter - please be careful adjusting anything - it took me months to get mine set up right - simply because I kept making assumptions on what was wrong.
All that did was throw ever larger spanners into the whole set-up.
Follow the checking procedure in the H-B link, and set up according to that.
Brent, IN
08-07-2003 19:02:40
 Re: Re: Re: Re: Re: Re: bush hog master control s in reply to Batman, 08-07-2003 00:54:18
James, Thanks for being patient with me. The H-B link is amazing! It looks like I have my work cut out for me. Thanks again!!!
