looking at TO35-please advise
Jason--New York
08-04-2003 17:26:02
This is my first time posting. I am considering a Ferguson TO-35 and I need some advice. I am a total novice with tractors: a city guy with a few acres to mow in farm country who cannot stomach the rider-mower routine. The one I am looking at starts very well, no smoke, great tires, solid hydrolics, has live PTO, ground speed and engine speed PTO lever and the H & L gear shift. There are many repair welds on the front wheel struts (I don�t know what they�re called: the cast scissor arms that span the front to the wheel posts). These welds actually fuse the two scissor arms on one side, and there is a plate there too, so there must have been some major cracks. The temp gauge doesn�t work�I ran it for a while and could feel the heat off the engine, but the gauge never moved. When I stood on the raised lifts on the back, they stayed up but I felt strong vibrations that were not there with no load. Also the paint is wrong, red hood and wheel guards and silver block, including the hoses, when I think the serial number (163305) indicates it should be a green belly. The manifold and exhaust are very rusty. The price is $2900. Finally, the dealer is a sly cranky old guy who has half a dozen dead 35�s for parts. Thanks for your thoughts.
Joe in Houston
08-06-2003 07:37:49
 Re: looking at TO35-please advise in reply to Jason--New York, 08-04-2003 17:26:02
Jason, I have to agree with the guys. The price is just a wee-bit to high. I paid 2000 for mine (1955 TO35) and with a coat of wax I could use it as a parade tractor. If you can swap out the welded front end that would be a bonus. I have to admit, after having IH, Farmalls and an AC grader when I was growing up, the little MF TO35 will stand up to all of them. This is a little tractor with a suprizing amount of power. I think if you have anywhere up to 10 - 15 acres that this little tractor will do you just fine. I use mine to do a lot of brush hogging with and it just keeps crawling along. I also use a dirt scoop on my 3 pt hitch a lot (Still looking for a loader). If the motor is solid and the leaks are minimal I would say offer the guy 2K for it. You wont be disapointed. Oh yeah. I got a manifold for mine from trustytractor.com for $75.00 (Half of dealer price)
Have a great adventure. Joe in Houston
kydirtfarmer
08-05-2003 10:55:50
Here's what I'd go for: $1800, and a front end out from under one of those "spare parts" tractors. It would be a good "first project" for you, to swap front ends. Not too tough.
9n141
08-04-2003 18:51:28
What location are you in N.Y.? I have a TO35 they are a nice tractor, manifolds are expensive, sounds like front end needs work.
Jason
08-04-2003 20:41:13
 Re: Re: looking at TO35-please advise in reply to 9n141, 08-04-2003 18:51:28
In Western Sullivan county--the tractor is on the PA side. I'm less worried about the manifold than the welded front end, and I'm wondering if that is a common repair or a sign of real danger.
James, UK
08-05-2003 00:10:47
 Re: Re: Re: looking at TO35-please advise in reply to Jason, 08-04-2003 20:41:13
As far as the front end goes, it sounds like the tractor has been severely abused with a front end loader on it.
Constant stressing because of heavy loads may have broken the front axle, and it would then have been welded back together.
I would feel nervous driving a tractor with a welded front axle, but parts are still available, so you could use this as a bargaining feature.
The 35 is/was a fine tractor - I wish I had one as well as my TED 20-85 (your TO30).
On a rough calculation, $2900 is about 1750 pounds, which over here would get you a nice-ish 35 in 'off farm' condition. I would try to get him down a bit on the price, around 2000 would be fairer, IMHO.
