TO-35 axle shaft bearing
mike
07-29-2003 10:05:55
Is the axleshaft bearing floating or pressed on to the axleshaft? I have managed to remove the retaining collar, but no dice on the bearing. If it was supposed to be floating , then i jammed it when i pursued the retaining collar removal.Anybody been here?
thanks.
john(UK)
07-31-2003 13:42:39
 Re: TO-35 axle shaft bearing in reply to mike, 07-29-2003 10:05:55
The bearing is pressed on, the collar is heated and shrunk on. To remove the bearing you will need to cut it off with a torch, being careful not to damage the Axle shaft. If you are doing this because you had an oil leak, it was all unecessary because you can but a simple kit that does away with all this mess.
