Inner Wheel bearing
Clint
07-23-2003 09:54:17
Okay this an add on to the message I posted yesterday regarding the front wheel bearings on a TO-20 I got the dust cap off and the outer bearing out and repacked as well as the entire hub from the spindle, I am unable to remove the inner bearing for packing or replacing, does it need to be driven out and if so then it would also need to be driven back in?? Any help would be appreciated.
john(UK)
07-23-2003 10:45:10
 Re: Inner Wheel bearing in reply to Clint, 07-23-2003 09:54:17
yes the outer cone of the bearing will need to be driven out, if you clean around the hub inside where the cone sits you should see two notches cut out of the hub to allow you to get to the cone so you can drive it out.To fit the new cone you have to press it is if you can, its not difficult to do. or if you have something approximatley same size you can tap it in place gently.
Clint
07-23-2003 12:58:12
 Re: Re: Inner Wheel bearing in reply to john(UK), 07-23-2003 10:45:10
I figured it out and the job is now complete, now all I have to do is get the parts I need and replace the lower spindle bearing and bushings, gee that should be a real chore thanks for all the help and when i get into the next project you will probably see more posts from me.
john(UK)
07-23-2003 13:24:21
 Re: Re: Re: Inner Wheel bearing in reply to Clint, 07-23-2003 12:58:12
Ok Clint..hope it all goes to plan now...You can just call anytime, no problem..Regards....John
