TO-20 Overheats-P.J.
Jerry
07-17-2003 10:50:03
Hi P.J., Regardinga temperature guage, you can get a universal temperature guage (capillary tube type)where the temperature sensor goes into a boss on the cast coolant outflow elbow that mounts on the cylinder head. It comes complete with a guage.
Regarding your problem, have you checked the timing and the carburator mixture to make sure the former isn't too retarded and the latter to lean? Other wise the suggestion from James re: a blocked radiator core or a damaged water pump seem like likely candidate. What about the lower radiator hose? Sometimes the pump suction can cause them to colapse and restrict the coolant out flow from the radiator. That's why they usually have a wire coil in them to prevent this from happening. Does yours? Hope this helps.
