TEA Ignition Timing
Ross (NZ)
07-14-2003 20:26:30
Can anyone help
I wont to check my ignition timing on what i think is a 1949 TEA 20.
I have checked the archives and note that there is a big difference in the points gap between a TO and TEA (22 THOU TO 15 THOU).
Before I do anything I just want to check that I have the right beast ie a TEA.
I cant read the ID tag under the steering wheel all I can dicipher is 295.
The Eng NO. is S56920E
The oil filter is at the left front and is inclined at around 15 degrees.
Can anyone confirm that it is a TEA and that the points gap should be 15 thou ???
Enjoy this site I check it everyday.
Thanks for your help
Ross
Jim W
07-20-2003 06:08:00
 Re: TEA Ignition Timing in reply to Ross (NZ), 07-14-2003 20:26:30
Are the 295 digits the first ones in the serial number by any stroke of luck?
If so you could determine the year.
Jim W.
john(UK)
07-15-2003 10:55:40
The tractor is a TEA or a derivative, fitted with a Standard Motors engine and the points gap should be .012" NOT .015" you are getting mixed up with the Continental engined version. You can check the page from the instruction manual at the address below.
James, UK
07-15-2003 00:54:47
Ross,
You have the Standard engine, so it is extremely probable that you have a TE type tractor, though whether it is a TEA, TEC, TED, TEE, or what is harder to tell without more info. TEA should be a petrol only engine - unless it was given a later TVO conversion - in which case you cannot tell if it was always a TED - if you see what I mean.
Your oil filter is inclined, so it is a later engine - mine is vertical and is an early type.
Go for 15 thou and see how it runs.
Ross (NZ)
07-15-2003 13:22:50
 Re: Re: TEA Ignition Timing in reply to James, UK, 07-15-2003 00:54:47
Thanks its a petrol engine. I think its been convereted to 12volt sometime in its past history.
Dick Nyquist, Sonoma
07-15-2003 18:39:51
 Re: Re: Re: TEA Ignition Timing in reply to Ross (NZ), 07-15-2003 13:22:50
Was the tractor not 12volt originaly?? I'm surprised by the comment about 12v conversion. Most Britich cars and (I think) all Triumphs of that period were 12volt pos ground. I would have thought that the tractor would be the same.
Dick, Sonoma
john(UK)
07-16-2003 13:16:06
 Re: Re: Re: Re: TEA Ignition Timing in reply to Dick Nyquist, Sonoma, 07-15-2003 18:39:51
The tractors changed over to 12v system at serial number 200,001 in 1951 any with 12v earlier than that serial number has been converted.
Dick, Sonoma
07-20-2003 16:12:16
 Re: Re: Re: Re: Re: TEA Ignition Timing in reply to john(UK), 07-16-2003 13:16:06
Thanks,
I wondered. Dick, Sonoma
James, UK
07-16-2003 00:43:24
Dick, the early ones were all 6V, and for many years British cars were 6V, too, up to the late 50's early 60's when the change was made from 6V positive ground, to 12V negative ground. This change I think also had some interesting side effects relating to electrolytic reaction in wet salty environments . . . . . . .
I certainly had a Ford Popular from 1955 that was 6V positive ground.
Quite a few of the early 6V tractors have been converted to 12V to allow better lighting, and starting, although the 6V system will start just fine if properly maintained.
Another factor over here is that 6V batteries now cost over 80 pounds new - and you can get a new 12V one for about 25 pounds - now you can call us Brits cheap, but we prefer to think of it as just being careful, ha, ha.
