TO 30 is running fine now
Tom H.
07-13-2003 14:31:23
First off thanks to everyones input to getting my 54 Fergy running again.
I went out this morning rechecked the timing and wires turned the key on and hit the starter. After 3 or so turns it fired up okay but needed to have the carb adjusted from the rebuild settings. I'm all set to start mowing again.
Thanks,
Tom H.
Gary H.
07-19-2003 08:13:12
 Re: TO 30 is running fine now in reply to Tom H., 07-13-2003 14:31:23
Tom,
I have a '54 TO-30 that just had the carburetor rebuilt. The guy that rebuilt it did not know how to set it properly, and it is barely running. It will only stay running with the choke pulled about a third way out. Do you know what the starting adjustments are for that carb? I would sure appreciate the help. I think I will do my own work on it from now on.
Gary H.
College Station, TX
Jerry/MT
07-24-2003 20:04:46
 Re: Re: TO 30 is running fine now in reply to Gary H., 07-19-2003 08:13:12
Gary:
The initial setting for the main jet is 1-1/4 turns out . The setting for the idle mixture is 3/4 turn out.
