Valve cover tightning
Dan Ct
07-11-2003 06:23:46
can somebody help me with the torque specifications for the valve cover on a 1952 to-30 also does gasket sealant go on bth sides of gasket.
thanks in advance to the people who help Danny
danct
07-14-2003 06:46:55
 Re: valve cover tightning in reply to Dan Ct, 07-11-2003 06:23:46
thanks John for your help i got the job done. sealant on one side only
Danny
John Fugit
07-11-2003 06:31:39
I am sure there is a "specified torque value" for the valve cover gasket, but I don't have that at my disposal. What I can tell you is that the sealant CAN be used on both sides, but I usually just do one. That allows me to remove it if needed, and to re-use the same gasket, if it's in good shape. (still sealing) I tighten the bolts to "snug" but be carefull not to over-tighten. Don't bend the edges of the valve cover. They will never seal again. I am sure that someone will post a message soon that wil give you the #'s you're looking for, but this is one of those things that is best suited to "common sense"
