TO-20 Parts
Clint
07-08-2003 12:24:58
I posted the message on 7/7/03 regarding the TO-20 backfire along with the broken rotor. After further inspection I have now located the problem, there is a clamp that holds the distributor into the block as well as holds the dist. and keeps it from turning, this clamp broke where the bolt goes through it threading into the block, sounds simple enough to replace until I tried to find it part has been discontinued and now I need help in where to turn in finding it. Any help would be appreciated.
James, UK
07-09-2003 00:24:33
 Re: TO-20 Parts in reply to Clint, 07-08-2003 12:24:58
Well done! You found the root cause, then.
Only three options left to you now:-
1 Fabricate a new clamp
2 Weld up the existing one (a good welder should be able to do this for you)
3 Search tractor breakers for a replacement second hand part.
(Breakers' lists have been posted here recently by someone - none of mine will be much help to you I suggest!)
Tell the board what location you are in - someone here may know of someone local to you.
Good luck
