Steering Box 1972 Massey Ferguson
Eileen
07-08-2003 05:55:05
While 'helping' Gary disc his fields I ran his 1972 Massey Ferguson tractor into another machine. Popped a tire. Now hydrolic steering is getting harder. Probably I damaged either the steering box, tooth blown, gears or seals. Looking for any ideas - anyone have these parts we can buy? Or ideas on remedies? Just need to get through a few weeks of less rain and hoping tractor lasts through it.
Thanks, Eileen
James, UK
07-08-2003 06:45:15
 Re: Steering Box 1972 Massey Ferguson in reply to Eileen, 07-08-2003 05:55:05
Eileen,
Not many 1946 - 1957 Fergusons were produced with power steering! :-)
You might get a better response from the Massey board, BUT . . . . . . .
Check the toe-in (tracking) on the front wheels, and check for bent tie-rods or bent front axle beam. Also check steering reservoir is full - and look for leaks after you fill it.
I work for a company that makes PAS pumps, among other things, and if you had damaged the pump, you would be able to hear it, and it would be really obvious - believe me. It would also not last very long if there were any chunks of metal floating around in it.
If you post to the Massey board, tell them what model number the tractor is eg 135, 595, 240, 1200, whatever to help them help you.
Good luck.
