Power steering or lack or it
dj
07-07-2003 21:06:51
need to know how to tell on a old massey fergueson 50A how to tell if pump or other part failure why you turn and turn wheel but the tractor goes straight. Pump is full of fulid. Is it the streering valves in the streering wheel?
Big Dean
07-08-2003 07:44:38
 Re: power steering or lack or it in reply to dj, 07-07-2003 21:06:51
That problem is usually caused by the oil bypassing a bad piston seal inside one or possibly both cylinders on that steering system.
James, UK
07-08-2003 01:59:12
Sounds like it could be the steering wheel valves - but check on the Massey Ferguson forum as well. It could also be the pressure relief valve in the pump is jammed open.
As far as I know, PAS operation is the hydraulic equivalent of an electrical Wheatstone Bridge - so for it to work, the 'resistance' has to change so that an effect occurs elsewhere - and it sounds like that ain't happening.
Be very careful with PAS (as with all hydraulics) - the pressures these systems work at will blow a hole straight through an unwary finger, hand, or arm.
