TO-30 Quadrant adj.
Bruce
01-04-2000 15:41:58
Can anyone help me diagnose my quadrant problem.
When I follow the IT book to adjust my lift system, I wind up with one or two situations.
1, when the implement begins to lower at the correct 2 1/2" of control lever travel, then the tractor will just barely lift the implement when the lever is all the way up. Or,
2, When the Q- is set so the implement lifts correctly, then it does not fall until the control lever is brought forward something like 3-1/2".
This is done having adjusted the spring tension at the upper link.
Any ideas?
Thanks,
Bruce
